Coolant for Hot climate
A tip
for you guys in the hot climates the coolant/antifreeze needs changing to the chemical/ organic type which is normally pink/orange in colour its a 5yr extended life use; the point being it has a higher boiling point 130deg as opposed to the blue 2yr type which is 108deg!! the chemical used also inhibits errosion better.
