Firstly I have apoligised to Twisty with a personal message and i have explained to him the reasons for my frustration with these items.I have been off the road for nearly three weeks,I have driven dozens of miles visiting all sorts of shops and dealers and when one said he could get me the items I thought happy days.Im still waiting. Hopefully next week I will get the little sods and hopefully I will be up and running again but IF they dont solve the problem which is fuelling related hence the need for a workshop manual then I will be off the road for some time.
I hope you can see where my frustration spilled over and Twistys sence of humour was missunderstood by me I hope this is self explanitory and I can still rely on the forums support.
						Damed relays
Re: Damed relays
i see you said that you had fuelling problems that might be related to the relays. What kind of symptoms?
I'll have a look at the relays as i've got some on a spare wiring loom and see if there is any makers identfication. morini obviously just sourced them in.
Re: Damed relays
looking at the headlight face on (looking to rear of bike)
from left to right
High beam relay
Electric fan relay
Low beam relay
above the 3 relays is the flasher unit
to the right of the flasher unit and slightly above is the Air temperature/pressure sensor
4 11/06 in workshop manual
the almost middle 20 amp fuse in the fuse box coils/injectors/fuel pump
http://www.sendspace.com/file/ootv6l workshop manual
						from left to right
High beam relay
Electric fan relay
Low beam relay
