Painting the wheels obviously required as strip down & rear disc removal.
Put the bike back together exactly as I'd taken it apart (apart from the new tyres
First run out showed speedo reading over 100mph constantly !!!
Not such a big problem till you consider that my run out added over 300 miles to the odometer for a run totalling under 100 !!! (logged top speed in the speedo impressive though
Anyway, turns out the air gap between the speedo sensor and disc bolts was too small - don't know why that shoud be as I put the same number of shims back on as before.
Have ordered a few more shims and for the time being put a thick O ring over the sensor to space it out a bit - all seems ok now, but will have to give it another run later in the week to make sure.
Dave H
