Abba superbike stand
unbelievable
Post by unbelievable »
Hi, I've got one of these stands and the fittings have fit the last three bikes I've owned, but unfortunately not the Morini. Does anyone have one and know what fittings to order? Thanks.
vtxbrit
Post by vtxbrit »
Hi I use one, they should know the sizes I dropped in there about 8 months ago and they measured my MM and gave me the fittings to suit (the Abba factory is about 2 minutes from my works) I told them that the left hand fitting was abit tight, so I will check the new part number and can confirm the number to you later today.
vtxbrit
unbelievable
Ha ha, they said someone had ordered some parts, but they didn't have the info on file. If you could, that would be great. Thanks.
vtxbrit
Post by vtxbrit »
I have let Alan (Abba) know the size of the bushes he supplied, he is going to check the part number and let me know, I will let you know part numbers as soon as I have it.
vtxbrit
vtxbrit
Post by vtxbrit »
Can anyone tell me if the Granpasso and the 9 1/2 use the same swingarm bolt as the Corsaro (Avio, 1200 and Veloce) bikes this is to help Abba stands list the correct kit number for their super bike centre stand
vtxbrit
vtxbrit
Post by vtxbrit »
Ok, I can now tell you that the Abba superbike stand kit number for the Corsaro range is "Kit 72" they are measuring the ground clearance on my Corsaro next week to confirm the model number for the front lift unit should you want one.
