you may be right.
The last time i noticed it was when all of a sudden when taking it for an mot it "hiccupped".
Immediate thought then was coil, but both are new replaced under warranty, although i realised that meant nothing.
The hiccup never reappeared , but it did seem odd at the time as it was dry, no rain and a very low rolling throttle.
when it reappeared it was pop, bang , bigger bang , kangaroo , keep the revs up , make way , i can't stop or she'll dieeeeeeeeeeeeeeeeeeeeeeeeeeeee
just died
Hello mr AA Man
To date swapped rectifiers, same voltage
swapped batteries , same voltage.
checked output from regulator by disconnecting to rectifier and running and starting on battery alone. Reading 11.5v on dash.
diagnostics on clock say no faults, because the battery isn't flat yet.
Now i could have two duff batteries, as they are both from italians and both the same make as supplied by morini.
I'm lucky that if the push comes to a shove i've got an alternator,but i'm not convinced.
I got my pal to tell me how to use a multimeter properly , but being thick i'll let him do the testing. He did explain to me how to check for current going to ground and so far no problems showing on the multimeter.
So its either , battery (i'll try a car battery for a few mins) as i don't want to make the alternator struggle to recharge a large car amperage battery.
Could be a duff dash, but i don't think so.
It runs in the garage , but i wouldn't trust it on the road.
all i need to see is the 13 to 14.5 volts on the dash
i've got a reading of approx 12.6volts with ignition off , is this normal or should it be about 13v
lovely bike , not perfect, its a love
hate
relationship at the moment
