0mph on Speedo
0mph on Speedo
Just been out for a ride on the Corsaro 1200.
Speedo reading 0mph at all times.
rear indicator flashes a couple of times then doesn't, front one double speed
when I stopped after a couple of miles, only reading 70C it looked like an awful lot of water pouring from left hand side of radiator, but doesn't seem to be coolant and stopped after a couple of minutes. Had washed bike at weekend and it was raining.
Injector light on periodically.
Am now completely lost as to the cause. Any ideas?
Nick
Nick
				Bulletje75
Re: 0mph on Speedo
Moto Morini's don't like water.
Let the bike drying. I allways spray some contactspray on all connectors in the winter.
Next time. Wash your bike withe care and not to much waterspray. It's an Ittalian. They are sensitive
Re: 0mph on Speedo
But the film on the website shows a red Corsaro being ridden through a puddle!!!!!!
						Re: 0mph on Speedo
Sounds like a problem with the speedsensor!
Regards sweden
						Regards sweden
Re: 0mph on Speedo
Odds are you'll have water ingress somewhere - check all the connectors.nicko wrote:Just been out for a ride on the Corsaro 1200.
Nick
The indicator problem sounds normal , if one fails the other will flash twice as fast.... sort out the fault to the rear and all should be fine again.
As well as sensor failure, an erratic speedo can be caused by a too large/small air gap - shims are used to set it correctly. Unlikley unless you've dismanteled it though.
Dave H
Ducati Multistrada 1200S DVT
Moto Morini Corsaro 1200
Beta RR300
Beta RR300
Re: 0mph on Speedo
OK, the indicator issue was down to a blown bulb, have replaced and all is well again.
I haven't dismantled the sensor so haven't changed the air gap. Still reading 0mph.
Injector light seems to have gone out, for now.
I am assuming the water was not coolant but rainwater running out of the radiator fins as the coolant level looks OK.
Nick
Nick
Re: 0mph on Speedo
Have you checked that both battery terminals are secure?
For the speedo, clean the face of the rear wheel sensor, with something slightly abrasive, or by scraping.
My veloce did the 0 mph thing, then as it wasn't happy, the engine light came on, loose battery terminals didn't help!
A man of many parts, none of which are fully functional
						Re: 0mph on Speedo
I damaged my speedsensor by using a rear padock stand. If the stand is placed to close to the sensor/cabel it might have been damaged, I know since I have managed to do this with my self causing 0 speed reading and injector light on.
Good luck sweden
						Good luck sweden
Re: 0mph on Speedo
Cleaned the sensor face yet? Mine started doing the 0 mph thing when I took the bike to have a new tyre fitted in the IOM, I was convinced that they'd damaged the sensor or it's wiring, or messed up the air gap, I "cleaned" the face of the sensor but that made no difference. It wasn't until I got home and attacked it with something slightly more abrasive that it magically started working again. Give it a go......
						Re: 0mph on Speedo
Haven't yet cleaned the face of the sensor, will hopefully attack it this weekend.  I'll let you know the outcome.
Nick
Nick
Re: 0mph on Speedo
Removed the rear wheel and cleaned the sensor face and the heads of the disc bolts, still no joy.  I think it's going to have to go to a service centre.
				MonstroMorini
Re: 0mph on Speedo
Did you have the rear tire changed? The sensor is often damaged by the paddock stand used. Take the sensor out and check it carefully for cracks - if any water gets in and it won't work - the orange light comes on.
Various ducati's use the same sensor.....
Re: 0mph on Speedo
Don't suppose anyone has a part number for the sensor???
