Check for leaks
Posted: 10 May 2025 18:16
Just a reminder to all you Dart owners to check for fuel tank/fuel tap leaks as part of your routine maintenance. It’s well worth the effort to take the panels off for a check- Even if you have an aluminium tank!
It’s well known that fuel tank and tap leaks are a problem on darts, and the aluminium tanks go a very long way to solving this. However if you still have an original fuel tap there are 3 common mechanisms by which leaks occur.
1) warped flange where it mounts to the tank (don’t overtighten!)
2) leak down the float tube and out the level sensor wire
3) leak out of the solenoid body due to cracking of the potting.
There isn’t much that can be done to cure these problems which potentially are worse with change in fuel composition and age, and of course new taps are not available, and not common to any other bike. There are options if you are prepared to forego the level sender although even these are very hard to find.
I had used a fuel proof epoxy to seal the very minor weep out of the float wire, and it’s held for 3 or 4 years, but during my checks before this riding season I’ve found the epoxy softened and cracked and whilst not leaking it’s definitely got fuel residue in the area, so I’ll deal with it.
Also worth while you have the panels off checking the oil cooler pipes, which can be known to split too.
