Dart with small oil leak
Posted: 08 Aug 2016 21:03
I seem to have a small oil leak (one or two drips on the ground when the bike is parked) it must be getting onto the exhaust because there is smoke and the smell of burning oil when the engine has been running. having cleaned the old oil and grease off the engine it is again wet, I know the oil seal from the gearbox output shaft (behind the clutch) needs changing although the clutch is not slipping......yet. Is there anywhere else that causes a problem? Also how difficult is it to change the seal?
What engine oil does anyone recommend for a 350 dart?
Regards Christine
Regards Christine
