Dart forks?
The Cagiva era Morinis
stevie-h
Dart forks?
Post by stevie-h »
Does anybody know which other bikes use the same forks as used on the Dart and presumably some Freccias?
One assumes that Marzocchi would not have produced a set of forks for such a low production run?
Needless to say my sliders are the worse for wear due to heavy handed maintenance by others in its past!
Re: Dart forks?
Dart forks are the same as Freccia C10 / C12, but with extenders screwed into the top.
Sliders or stanchions?
If it's the sliders then I might have a pair. If it's the stanchions, then I suggest talking to Disco Volante. They're Paoli/Tarozzi agents and can supply stanchions for about £140 per pair (+vat).
It's also possible to upgrade to early Cagiva Mito/Planet (non USD forks), which means you also have a 17" front wheel.
