My Kanguro has really not been yet on the road for more than test rides and I couldn't help noticing the terrible noice
Well, the reason is that the lower chain roller didn't have any surface material left (nylon probably) but the bearing was there; metal against metal.
This roller seems easy to replace with cheap commercial alternatives. What is the diameter of the original (must be at least 45mm)?
Also the swing arm upper chain 'slider' - or what ever you may call it - there was nothing left other that the small bolt and a couple of small bits of nylon.
Finally the questions:
The upper 'slider' - what does it look like (height etc) and if I want to make a replacement myself? Or where can I buy one?
Have spent long time trying to google etc...
Any pictures anyone might share with me?
