ignition timing
ignition timing
Hi. Could someone please help me with the correct ignition timing proceedure for the 175 Tourismo. I cant find it anywhere in my records. Degrees before top dead center or measurement etc etc. Thanks in advance.
- Site Admin
Re: ignition timing
Bob, I have got 2 owner manuals of 2 different 175cc models. As I am the administrator of this forum (and can manage users), I looked up your email address and will send those 2 manuals over.
Hope that helps!
Hope that helps!
Re: ignition timing
Thanks but the timing data isnt included in the manuals. There must be a record somewhere of the technical data, what about all the piston ring gap and clearances to bore cleances? I cant see how anyone could rebuilt an engine properly without more data?
Re: ignition timing
page 27 & 29 on this manual gives the data depending on engine type, hope your italian is any good
https://www.rpw.it/Files/Morini_175eGT_UEM.pdf
this manual on page 20: https://www.rpw.it/Files/Morini_175_UEM.pdf
here are some electrics diagrams: http://www.alzavalvole.it/manuali-moto-d-epoca.html
here you can buy some: http://www.registrostoricomotomorini.it ... italia.htm
If the data is not there you may have to talk to an expert who knows standard tolenrances for (Italian) bikes from that era
"Innamorato di vecchi motocicli Italiani"
Re: ignition timing
Thanks Tintin. Thankfull Tony found the timing data for me in a GT manual, I had it all along , just couldnt read it!
Here is a question. Is my bike a late Tourimo or an early Tresette?
You do not have the required permissions to view the files attached to this post.
- Site Admin
Re: ignition timing
You're welcome!
To me, your bike seems more like a Tresette. To be really sure, you should have a look at the cilinderhead/rocker cover.
I have got an excellent article from the Italian motorcycle magazine "Motociclismo d'Epoca".
It shows the various 175cc models and the differences. The picture above is from that article.
I'll send you the article by e-mail in a .zip file
This is a 100% Tresette, but seems to have a Tresette Sprint toolbox:
Aparantly, this black Tresette a later model with different toolbox and different/longer fuel tank.
- Site Admin
Re: ignition timing
Here's the answer to the question:
According to the book Sempre pui' Forte, written by Wim Raeymakers, there is an early and a later version of the Tresette:
The early model.
The later model.
These pictures above are factory pictures taken from a very rare CD ROM.
The early model.
The later model.
Re: ignition timing
If anyone else was seaching for the same information about timing its 9 degrees BTDC. Total with auto advance fully open its 40 degrees.
