Right hand shift conversion, 81' Camel
Posted: 16 Sep 2020 02:56
by forzamacchi
Hello everyone,
I have heard that there is a conversion for turning my camel back to right hand shift? I have a US market left hand shift Camel with the weird cross linkage. Any tips appreciated! Ben
Re: Right hand shift conversion, 81' Camel
Posted: 17 Sep 2020 10:33
by Steve Brown
Have never heard of this kit for a Camel, only for the road bikes?
I wanted right foot change for my Camel and discovered that the gear linkage from a 500W road model (or equivalent 350 I suppose) fits perfectly. Depending on what you do for footrests you may not even need a linkage, you may find a standard Strada gear lever will do. I went this route as I was also fitting the starter motor from the road bike.
Swapping the rear brake to the proper side, I welded an outer cable stop to the frame on the left side and routed the (home made) cable up over the chainguard and through the frame, underneath the tool box/battery area. For convenience I fitted a stop lamp switch in the cable. You'll have to mackle up your own brake lever too.
Posted: 17 Sep 2020 16:48
by 3potjohn
I am happy enough with a right hand gear lever on my Sport and a left hand one on the Coguaro, the riding positions are so different I do not have a problem. Well except for yesterday when on the Sport. On the Coguaro the reserve tap is on the left. As I was going “pretty well” on the Sport I reached down to turn reserve on and instead grabbed the ignition switch and turned it off.
Sloppy linkages do not help either way.
Posted: 21 Sep 2020 04:43
by forzamacchi
Thanks John.... pulled the linkage and it is indeed a sloppy mess. New ends on the way...Ben
3potjohn wrote:I am happy enough with a right hand gear lever on my Sport and a left hand one on the Coguaro, the riding positions are so different I do not have a problem. Well except for yesterday when on the Sport. On the Coguaro the reserve tap is on the left. As I was going “pretty well” on the Sport I reached down to turn reserve on and instead grabbed the ignition switch and turned it off.
Posted: 21 Sep 2020 04:44
by forzamacchi
Thanks for the tips Steve! Ben
Steve Brown wrote:Have never heard of this kit for a Camel, only for the road bikes?
