Camel swing arm bearings/ Headstock
steve pegg
Post by steve pegg »
I am stripping down my Camel for a frame respray, almost there but... The headstock bearings; are they an interferance fit ? How do I remove them? Also the swinging arm bearings, same again best way to remove please?
Finally the oil seals top of forks; the seal below the circlip ;again what is the removal technique?
Thank you
steve pegg
Re: Camel swing arm bearings/ Headstock
Found out elsewhere so will answer my own Q? As no one seems to know. Mine is an 87 Camel and all the above seals /bearings are interference fits. Knock out head races/cones from inside down through the headstock a little heat helped me. But do not forget the circlip on the fork seals.
Chips1953
Post by Chips1953 »
steve pegg wrote:Found out elsewhere so will answer my own Q? As no one seems to know. Mine is an 87 Camel and all the above seals /bearings are interference fits. Knock out head races/cones from inside down through the headstock a little heat helped me. But do not forget the circlip on the fork seals.
Well that's what I am doing, good job you answered the question yourself.
Will try to pull the swing arm bushes out.
Singer 185K
Wheel Horse commando 7
Honda SS90 1965
