Kanguro X3 chain
buzby
Kanguro X3 chain
Post by buzby »
Can anybody tell me what is the correct size and lenth of chain for X3 kanguro ?,
thanks,
Dave.
David
75 350 Strada, 76 350 Strada, 76 350 Sport. 80 250 vee, 72 Triumph TR5T and 81 Honda CB250RS
Jem
Re: Kanguro X3 chain
Post by Jem »
the correct chain is 106 links of 520 chain. That's with the standard sprockets of 14/47 teeth
buzby
Post by buzby »
Jem,
thanks for the info but after a dirty afternoon in the workshop comparing chains with my other bikes ,I,ve decided it has 530 size sprockets , 14 and 48 tooth. 106 links looks about right though.
I,ve got a spare back wheel from, I think, an early Kanguro and that does looks like a 520 size.
David
What ever you do DON'T fit a 530 O-ring chain, there's a danger of wrecking the cases.
The whole reason they went to a 520 was that in O-ring form it's about the same width as a plain 530.
Sprockets aren't that expensive from Sprockets Unlimited and especialy if you're fitting an O-ring chain, it's usually false economy to fit a new chain to worn sprockets.
