Grimeca Rear Caliper rebuild
Posted: 17 Jul 2019 22:45
I have a problem with the Rear caliper on a 500 SEI.
The caliper seized up and needed a rebuild.
Purchased a set of seals from NLM but could not get the pistons as none available and ours were quite badly pitted, beyond a little refacing.
Managed to get a pair of 28mm pistons that were intended for a Brembo caliper via another supplier who stated "morini owners have tried but they have not been too sucessful"
The bike has stood in the garage over winter and have come to it and found the caliper is weeping oil past the seals.
Questions 1
Where to get parts for the Grimeca, does anyone know of substitute parts.
Question 2
Are there any good substitute calipers around, ie brembo etc.
Also trying to get the taper tool to refit the clutch (it was leaking too) tried Ndina, 6 voicemails left, and 5 or so contact forms filled in and not a single response to date.
Where can I get these taper tools from other than having them made.
Questions 1
Question 2
