Virtualy every comercially available, including Mdina Italia, 124L075 cam belt I can find is a metric equivalent ie nominally 314.33mm.
That is with the exception of MEDWAY with a true 12.4 inches ie 314.96mm
cam belt sizing
Re: cam belt sizing
as far is i know the 124 is the number of teeth on the belt ,
not the length in tenth of inches.
Re: cam belt sizing
124 is the "outer circle" measurement, there are 33 teeth.
Charlie Mullendore
Re: cam belt sizing
124L075 is the identificacion of the right belt. The Optibelt ones use to cost less than 10 €.
As they are industrial belts they are not measured but uce to fit. I´ve allways used them on B camshaft pinions without problems.
