Sugar cube fuel tap for 3.5
Posted: 06 Apr 2021 20:18
by Lewes96
If anyone has a spare one.Cheers
Re: Sugar cube fuel tap for 3.5
Posted: 23 Apr 2021 14:29
by FatherB
Try Officine08.com They have loads of taps on there.
Posted: 03 May 2021 16:24
by simonnorthroad
Found taps on he Officine08 website with some difficulty. It hasn't got this kind of tap you want. Don't bother
Posted: 03 May 2021 17:51
by Lewes96
Thanks for the tip but had a quick check and sure enough none there.
Posted: 04 May 2021 17:37
by simonnorthroad
Gutsibits has them occasionally and HMB Guzzi in Germany but the latters' postal costs make them.expensive
Posted: 04 May 2021 18:33
by MickeyMoto
Posted: 05 May 2021 08:08
by mbmm350s
Have you tried discovolante , common to some Ducatis I think.
Posted: 07 May 2021 10:18
by BumbleBee
Apologies if you already decided against, but a popular option is to replace it with a manual tap from a V50 Guzzi and gain the advantages, or even to do both taps like this.
G&A
Posted: 08 May 2021 12:02
by mbmm350s
BumbleBee wrote: ↑07 May 2021 10:18
G&A
Exactly as I have done, use a V50 etc tap available from Gutsibits about 1/3 price of a Paioli tap , also has reserve if you want.
I use it as the main tap and the electro tap just stops the fuel leaking out of the tank.
