Hallo everyone!
i'm looking for a front brake pump for my morini 350 K2
the bike has twin disks on the front, so the pump is the same as the 500, it is a grimeca item and it has a 18-19mm piston
anyne can help?
a good rebuildable unit il also welcomed
thanks in advance
Gianluca
front brake pump
front brake pump
cosworth
924T
Camel 501
924T
Camel 501
Re: front brake pump
Are you still looking for this? Are you sure it is 18-19mm is what you need?
I have a 16mm master cylinder (pump) from a 350 Sport which I've replaced with a 12mm which suits the single disc much better; I think the 16mm would serve you well
