Page 2 of 2
Re: Carb balance
Posted: 13 Mar 2020 07:24
by Ming
- Fork oil.png (263.58 KiB) Viewed 3587 times
Re: Carb balance
Posted: 13 Mar 2020 07:28
by 72degrees
Opinions vary on fork oil capacity/grade. It depends on the forks. About 200cc ish and 10ish weight might be a starting point. Ming's technical chart suggests that's about right
For example see:
viewtopic.php?f=4&t=2054&hilit=fork+oil+grade
Re: Carb balance
Posted: 13 Mar 2020 14:46
by norbert
Forkoil more or less 200ccm in each leg. I normaly use SAE 15 (and found out that with old drumbrakeforks from Pailoli to me the SAE 15 was a bit too hard). Other people prefer SAE 10 en general
Re: Carb balance
Posted: 13 Mar 2020 16:12
by 3potjohn
Did mine last week.I used 220mL of 15Wt oil per leg in my 83 K1 as usual. Interestingly one leg produced lovely clean oil and the other produced a filthy grim looking liquid. I run gaiters on the stanchions. Must be something degrading I guess.
Speaking of filthy looking grim liquid a bar down the road is doing American Imperial Stout at 10.5%. If you like Rocky Road it’s delicious.
Re: Carb balance
Posted: 14 Mar 2020 11:50
by nicko
3potjohn wrote:Did mine last week.I used 220mL of 15Wt oil per leg in my 83 K1 as usual. Interestingly one leg produced lovely clean oil and the other produced a filthy grim looking liquid. I run gaiters on the stanchions. Must be something degrading I guess.
Is the American Imperial Stout the same thickness as the fork oil?
Re: Carb balance
Posted: 14 Mar 2020 15:35
by 3potjohn
Probably a bit thick with too much of a damping effect.. The 7% one might be better considering.
