Kid not included.
So, I did some front end work since the front brake really wasn't stopping the bike and both fork seals were leaking. I had an extra rotor given to me in the deal and so I had that one skimmed and burnished. I also got new brake pads. Now I have a severe studder! I know that the machinist who dressed the rotor used the backing plate (where the rotor mounts to the wheel) as a guide for how level the rotor should be. Was that a mistake? Are these rotors at a slight offset or something?
Also, I noticed that before red-line in each gear when I am around half throttle the bike just doesn't go any faster. Wondering if this is a carb issue or should I look at something else? The bike runs fine a low RPM in each gear. Also, I did remove the carbs from the bike for a good cleaning with carb cleaner and comprssed air. The main jet is 115. Should it be bigger?
Any advice would be appreciated. I really like the bike when it is behaving. Hope to get these things worked out soon.
LTR
Memphis, TN
