forked
forked
so i bought tarozzi stanchions for my 350 sport from tarozzi via wemoto (not pantah) but my cap tops have a different thread, possibly 1.5 and the forks seem to be 1.25, looking about the web
its possible that paoli forks had 1.25 thread can anybody confirm?
steve
steve
Re: forked
Hi Steve,
Sorry but I can't help you re: Paioli, but I had the same issue with Tarozzi stanchions 5 years ago, but back then I was able to see NLM. Rob came to the counter with a box of used tops and I was able to get a pair that fitted. Maybe worth talking to Mdina and asking the question if they could look in their box?
Re: forked
The thread on my original Paioli fork top nuts is 1.5. They're on a 1975 Strada.
"I'll have a V please, Bob."
Re: forked
ive spoken to mdina and they say they will search so far theyve only sorted the stuff thats recorded at nlm and there is more,
george have you got any info, pics about your find?
steve
steve
Re: forked
Will have a look when I'm back home.
Re: forked
Hi Steve,
Hopefully the attached will help?
If you can't see it, pm me with your email and I'll send my fork notes/pics to you.
- 2 old and new fork cap nuts.jpg (68.15 KiB) Viewed 7429 times
Re: forked
thanks for that i guess the one one the left fitted the tarozzi any pt no?
steve
steve
Re: forked
Sorry Steve, no different numbers. Was the box of s/h nut and a sort through.
But. An interweb search brings up www.classicducati.com . Do a search for item SS21and all will be revealed! Do lots of little items of interest to Morini owners.
Regards, George.
Regards, George.
Re: forked
george
youve showed me yours heres mine: 81 sport
- fcap3.jpg (321.58 KiB) Viewed 7370 times
- fcap2.jpg (346.36 KiB) Viewed 7370 times
- fcap1.jpg (424.37 KiB) Viewed 7370 times
Re: forked
hmm slight scale problem!
Re: forked
george
looked at the duke site so do you think that their one mill cap is the same as your left pic?
Re: forked
I'm pretty sure it is. Going back to your original question regarding thread pitch, If you don't have a thread gauge, then get yourself a standard 6mm and 8mm bolt. Place each bolt in turn into the threads in the top of your fork tubes and only one will accurately mesh into the threads.
If it is the 6mm, then the classic ducati ones are what you need (1mm pitch). If it is the 8mm then you have a problem and will need something else (1.25mm pitch)
I've only ever seen them in 1 or 1.5mm pitch though, and my Tarozzi stanchions are 1mm.
Regards, George.
Regards, George.
Re: forked
well ive ordered from classic duc so we shall sea,interesting about threads maybe i should get a gauge any recommendations?
steve
ps anybody welcome to huntsman mcc show eridge station e sussex next sun 10 till four
pps well maybe not axe murderers!
steve
Re: forked
got the fork caps and they fit but tarozzi (via wemoto) say that i probably have k series forks! so now i have composite forks is this a problem?
tarozzi sent drawings which maybe of interest but ill have to convert them from pdf as apparently you cant post them!
Re: forked
tarozzi drawings
