Front Sprockets
Front Sprockets
Does any body have knowledge on the change of gearing on the Moto Morini Corsaro Veloce.I am not wearing my tires out fast enough and have surprising fuel ecconomy.The standard front sprocket fitment is a 17 tooth.I would like to fit a 16 tooth front sprocket but need to know if the output shaft spline pattern is a common generic type between other motorcycle brands or not? I am hopeing that I can walk in to a local Ducati or Honda dealer and purchase a 16 tooth front sprocket and it will be splined identically.
Re: Front Sprockets
Guvo,
did you get an answer to your question or get a 16 tooth sprocket. I'm thinking of doing the same. Would like to hear your comments about how it goes
Bondo
Bondo
Re: Front Sprockets
Although a 17 tooth front sprocket is quite large compared to some bikes I personally would do 3 larger on the back (the equivalent of appx 1.2 smaller on front), a smaller front sprocket will wear the chain and sprocket quicker and put more point load on the gearbox output shaft.
vtxbrit
vtxbrit
Corsaro Veloce
Aprilia TuonoV4 APRC
4V 500 Weslake Barber grass tracker
2V 500 Jawa Hagon grasstracker
500 Jap 4B Barber grasstracker
500 Jap 5stud jawa speedway
