Page 2 of 2
Re: 501 Ignition timing
Posted: 25 Nov 2020 08:59
by pedro
Something is wrong there Mark, when I had the bike it was an easy starter, in fact I would always take that one out rather than my NLM ignitioned one because I could always rely on it starting. (that changed when I put that one back to standard ignition and it became a pussycat)
I'm wondering if the ignition system has developed a fault, perhaps the Sachs syatem might be the way to go.
You could get it down to Benjy Straw, he knows the bike.
Posted: 25 Nov 2020 17:44
by huggins3719
MickeyMoto How many turns out from fully screwed in did you have to turn the mixture screws? I take it you have Del'Orto PHBH 28 carbs fitted the same as mine? Screw in to weaken screw out to enrich the mixture.
Posted: 25 Nov 2020 18:26
by 72degrees
MickeyMoto wrote:
I put a Kokusan 501 in a Strada and it kickstarted ok, but did need a firm kick. As Norbert says, find compression then kick. A motorcycle boot is needed, not a pair of sneakers. It kicked back at first but after setting the idle mixture screws (or whatever they are called) and the timing dynamically it was ok.
I just started the Forgotten Error while wearing plastic garden clogs. It has stood unused for 18 months. OK, 6 kicks to get the first brief run, because I forgot to give time for the float chambers to fill. Red OEM pickup, NLM module and generic coils. That's with an L5 cam, PHBH28s and no base gaskets.
Posted: 25 Nov 2020 18:35
by MickeyMoto
Yes, but it didn't have Kokusan ignition!
If I remember I initially set the 'mixture' screws to 1.5 turns out, but it wouldn't run off choke so went out to 2.5 out and it ran with no choke. Adjusted from there.
Posted: 25 Nov 2020 20:25
by huggins3719
Pedro you recommend I let Benjy Straw check my bike. Would you provide contact details please .
Thanks and regards
Posted: 26 Nov 2020 07:47
by 72degrees
MickeyMoto wrote:Yes, but it didn't have Kokusan ignition!
Both good points well made!
Is it possible to retrofit my preferred setup on a currently Kokusan equipped 501 (or Dart) ? Though I'm guessing parts for the Kokusan are more easily sourced than say an OEM red pickup !
I have the SWF ignition 'solution' ready to fit on the hack. Inertia has prevented me doing so, as it runs the same as the FE, so not huge motivation. Action this day! Well, before the spring anyway.
Posted: 26 Nov 2020 09:17
by pedro
Mark.
Benjy's details are in the club mag, ATG, Mobile is 07771 554570
If you think a Sachs ignition might be the way to go, you will need to be quick, the order is going in shortly. Only thinking 40 year old electrical components are getting somewhat old, something is wrong somewhere.
Shame Paul Compton doesn't want to look at it, he would be closer for you. Does anyone know what he's up to?
Posted: 26 Nov 2020 09:38
by MickeyMoto
72degrees wrote:MickeyMoto wrote:Yes, but it didn't have Kokusan ignition!
There are similar CDI units available, but not sure if the part numbers are the same. Would Kokusan make a Morini specific cdi unit?
I do not think the kokusan bikes use the pickup under the left side cover, as the timing is done on the alternator side. Are the threaded holes there to fit the plate?
Might be worth having a peek inside. Watch out for spiders!
For me, I will keep running standard until it breaks.
Posted: 26 Nov 2020 10:18
by 72degrees
MickeyMoto wrote:72degrees wrote:MickeyMoto wrote:Yes, but it didn't have Kokusan ignition!
OK, that makes sense - though the last bit might depend on where you are when it breaks
Posted: 26 Nov 2020 13:57
by 3potjohn
It’s my understanding that for Kokusan ignition you can source the stator and CDI on ebay cheaply as they are used on some species of Kawa and Suzi bikes but the rotor is another ballgame. Soren’s video on Kokusan explains it clearly.
My. Rotor is currently on holiday in deepest Devon (Pennymoor) where I am hoping it will come back sans metal ring.
Posted: 27 Nov 2020 23:28
by pedro
Mark,
Just a thought, but what are you now running, air filter wise?
When I had it, I was doing a lot of track work and had conventional carbs to air box rubbers going up under the tank, with nothing on the ends of them.
If Denis put filters on it would change the carb settings quite a lot.
